FCT Tower Stripped
  • NCH2oSki
    • 1159
    • Maryville, TN
    • 2005 ski nautique 206 SE
    FCT Tower Stripped
    My fct 2nd generation has a problem. The threaded leg that the tower bolt with the big black knob goes into has stripped out on me. I ended up taking the folding section off to make it to the lake this weekend.
    How do I repair the stripped threads? The tower is aluminum, does that pose any issues on using something like a helicoil?
    Prior Boats:
    1999 Ski Nautique GT-40
    www.skiersofknoxville.org
  • core-rider
    • 1375
    • Huntsville, AL
    • 2003 Black SANTE
    I stripped one side out last season. I repaired it with helicoils and it's holding up well so far. You need to be real accurate with the angle at which you drill the hole out. If it doesn't line up right the bolt will not want to thread and will bind. Take your time with that step. Also, I installed 2 coils on either side so there would be plenty of threads for the bolt to bite on. You will just have to break off the end of the top coil once installed. I went ahead and did both sides knowing it would have to be done eventually. CC should have done helicoils from the start IMO.
    Jason
    All black 2003 SANTE
    -- Southern Fried --
    • ronskal
      • Jun 2010
      • 58
      • San Angelo, Texas
      • 2010 SAN 210TE
      Agree with Core. Helicoils work real good into aluminum like your tower. Use Loctite to retain the helicoils.
      sigpic
      2010 SAN 210TE
      2004 Mastercraft X2 (Sold)
      2005 Sea Ray 210 Select (Sold)
      • steve-o
        • Jul 2009
        • 231
        Third vote for helicoil.
        • NCH2oSki
          • 1159
          • Maryville, TN
          Picked up a helicoil kit today from napa, should be the ticket!
          Prior Boats:
            I am late to the party on this one.
            Helicoil, and Loctite. Do not put the knob in until the Loctite cures, and do not use an excessive amount of Loctite.
            • AirTool
              • 4049
              • Katy, Texas
              I'm curious...which loctite? the one that requires heat for removal?
              • core-rider
                • 1375
                • Huntsville, AL
                • 2003 Black SANTE
                I didn't put any Loctite on mine and haven't seen any problems yet. I did make sure to tighten the second helicoil as tightly as it would go to help hold them in place though. I would think the blue Loctite would be more than sufficient.
                Jason
                • steve-o
                  • Jul 2009
                  • 231
                  If the helicoil is installed properly, you won't need loctite.
