When replacing the transmission oil cooler, what do I need to know/watch out for as far as the transmission oil is goes? I assume some oil will leak? Does a lot leak? Is there a way to keep it from leaking? Should I let it leak and top off when I am finished?
Thank you in advance for your assistance.
