After running navigation lights for about 10 or 15 minutes the circuit breaker will trip. All of the lights are functioning properly. Not sure what the problem could be. Anyone else had this issue?
Hopefully someone will chime in who has had a similar problem. I don't know if you can unplug the lights or not. If so, I would disconnect the bow light and run with the lights on. If you still have the problem, disconnect the anchor light and do the same. Keep eliminating things to narrow your search. I suppose that it could also be a weak breaker.
I wish I was more help.
