I was out yesterday and the boat was running kind of rough. So I replaced the plugs and added some seafoam. It seemed fine, but the check engine light was flickering every now and then. As I was ideling in it just shut down and wouldn't start. Today I went to start it to see if I'm getting fuel up to the fuel rails and it is squiring out the valve. It will run for a couple second then shuts off. It also was backfiring? Could the timing be off?
Do this:
http://www.planetnautique.com/vb3/sh...ressure-Check&
Do this:
http://www.planetnautique.com/vb3/sh...ignition-test&
Check the safety lanyard switch for bad connections.
Down load the GT-40 service manual from this site
The relay does not move fuel.
The fuel pumps do.
I would suspect the low pressure fuel pump.
I do have one low pressure fuel pump sitting on a shelf that would not draw any fuel until it was primed. Then it pumps just fine.
There is gas in the tank? Are you sure?
If you do this, you will be handling gasoline, in open containers, in your boat. Be very careful.
Review my post on checking the fuel pressure. That shows you how to turn the fuel pumps on.
There is a hose connected to the side of the FCC that is the return line back to the fuel tank. Disconnect that hose, put a can under the open fitting. When you turn the pumps on, you should get good flow, about a quart every 15 seconds. Plug this fitting with a fuel pressure gauge. You should get 5 to 6 PSI.
If you have good flow here, and good pressure with the fitting plugged, with the pressure gauge I would think your low pressure pump is good.
This is not the pressure you need at the fuel rail on the engine. that should be 39 PSI, fuel pumps on, engine not running.Last edited by DanielC; 07-05-2010, 09:54 PM.
temp and oil switch would never cause this problem funny how it's alwys over looked as a cause for the computer shutting down the motor right after it's starts bet it went in to limp mode before you turned it off the first time too, but where under idle and didn't notice that it did.
