Cuts out after hitting wave
  • Bobby
    • Jul 2004
    • 87
    • Norman, OK
    My 96 Sport w/ GT-40 EFI will cut out for a split second after I drive over a boat wave. Once I pass over the waves and get back to smooth water everything is fine. Anyone know how to get this taken care of?
    1996 Sport Nautique w/ EFI GT-40
  • red89
    • Feb 2009
    • 23
    Check for lose ignition connection under the dash. Often a lose dashboard, or connection can do that.
    • NautiDave07
      • Mar 2008
      • 333
      • Louisville KY
      • 00 SAN210 07 236 TE
      Not sure if yours would be the same as mine was but mine would do that sometimes. It was a 2000 superair with gt40 it was the glass fuse at the battery. It was a plunger type fuse holder and it was worn. Connection would come loose and boat would die. Change the fuse holder and never had the issue again.
      00 SAN 210 (previous boat)
      07 236 te sold
      • Lvnspeed
        • Aug 2008
        • 393
        • Smith Lake AL
        Check the battery cables also check the grounds on motor make sure they are clean and tight.
        2003 226 LE
