Put the boat in the water yesterday for the first time this year. When it started up, I noticed a little excessive steam coming from the exhaust. The lake water was super cold, so I figured it was normal (as I've read on a few threads on this site). When I opened her up for the first time, there was a pretty large amount of what I would consider white smoke in a cloud left behind me. After about 15 seconds it stopped, so I figured it was just clearing itself out (?)
I'm not noticing any more than the normal steam that dissipates coming from the exhaust, but I do feel a loss in power out of the hole. Also, at lower RPMs, the engine is running rough. She seems to run super rough on a tight turn as well. Top end seems fine once I get on plane, but I've never had a problem pulling a rider out of the water until the other day. The oil looks normal, no abnormal coloring, so I don't think I've blown a head gasket or cracked the block. I've read a couple of similar problems on here, but nothing exactly like what I'm experiencing.
I did have plugs and wires replaced last year, could there be something faulty there? What else should I check before I drag her 60 miles to the nearest trusted mechanic? Could the initial smoke from earlier in the day be connected to this problem? Any help would be greatly appreciated. Thanks
