I just got a 1980 ski nautique and it runs good just has a vibration through the drive line...It seems to be straight and the prop does not look to dinged up, there is a little play in the part that is under the boat that holds the drive shaft, if the bushing gets wore will the boat vibrate on the gas an when you turn??
Thanks T-MEZ
Thanks T-MEZ
