Bearing buddy keeps coming off
  • Chexi
    • Jul 2026
    • 2119
    • Austin
    • 2000 SAN
    Ok great pn brain, I have had a bearing buddy come off the same wheel two days in a row on 10 mile trips. I know for sure the second time it was tapped all the way in by a pro and lubed with the grease gun special tool. Still lost it the next day. Any idea what could be causing this? I thought someone stole it the first day, but not two days in a row on the same wheel.
    Now
    2000 SAN
    Previously
    1999 Air Nautique
    1996 Tige Pre-2000
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    Wheel Hub Stretch
    Since it's a friction fit there is a good chance that the hub itself has stretched or the one the pro put on was a smaller diameter. I think there are 2 or 3 sizes. They are made by UFP in San Marcos California just north of San Diego. Here is the link http://www.ufpnet.com/ContactUs/tabid/60/Default.aspx If you call them they can probably help.
    Nautiqueless in San Diego
    • 81nautique
      • Feb 2006
      • 257
      • Big Rock, Illinois
      • 2012 200 Sport 1956 Correct Craft Collegian Past boats 1955 Correct Craft Hurricane 81 Anniversary Nautique 1960 GlassCraft Ski Nautique #1
      Jack your trailer up and check to see if the wheel has any wobble to it. Could be a bearing going bad or not preloaded correctly last time they were serviced and may need to be tightened a bit.
      • jhiestand
        • 786
        • Columbus, Ohio
        • 08 Super Air 210
        This has happened to me also, and the cause was a loose wheel. I lost two bearing buddies before I figured out what was happening. I agree with 81nautique, check the wheel for looseness.
        '08 Super Air Nautique 210
        • Chexi
          • Jul 2026
          • 2119
          • Austin
          • 2000 SAN
          Thank you all. I will start with checking whether the wheel is loose (the easiest fix). Hopefully I will end there.
          Now
          2000 SAN
          Previously
          1999 Air Nautique
          1996 Tige Pre-2000
          • JUST-IN-TIME
            • 293
            • ON YOUR BOAT
            i use blue loctite on them
            HUMAN BUILT = HUMAN FIXED
            switchbait.com
            • mf01
              • Jun 2005
              • 515
              • Austin, TX
              I had the same problem about a year ago. The hub/drum was warped. I replaced it and now it stays on.
              Previous:
              2011 Super Air Nautique 210
              1994 Sport Nautique
              • TRST
                • Mar 2009
                • 44
                A temporary fix is to use a punch (with the beraing buddy installed) to create some dimples on the the lip of the hub making a tighter fit. I had to do this on a trip and it got me back home.
                2007 196 Limited Zero Off
                • mrbobolina
                  • Sep 2008
                  • 107
                  Two real options. One don't get a bearing buddy. Walmart carries something that is like a bearing buddy, same concept, only a fraction wider. When you smack it on be sure to use like a piece of 2X4 on top of the buddy and whack it with a hammer nice and tight.
                  Option 2 replace the hub. This is actually really simple, although the hub will probably run about $150 when you include new bearings. If you go this route, I am not sure if you have to replace the bearings in pairs?
                  Your buddy is coming either because you are not setting it deep and even enough or your hub is just stretched.
                  • Chexi
                    • Jul 2026
                    • 2119
                    • Austin
                    • 2000 SAN
                    I'm going to run a few tests. When it came off the second time, I had the trailer parked (without the boat) in an area that had really bad roads. As a result, the trailer bounced quite a bit. Since the hub is probably warped a bit, I suspect that the excessive jarring caused the BB to pop out. I'm going to tape a baggie around the hub with some extra space and drive over that area again and then look at it to see if it (a) popped off, (b) came loose, or (c) still in tight. Then I will report back. Unfortunately, that won't be for like 2 weeks, since I'm going to wake camp next week.
                    Now
                    2000 SAN
                    Previously
                    1999 Air Nautique
                    1996 Tige Pre-2000
