2007 SANTE 220 prop got jacked and what do I do?
  • Fwat220
    • Sep 2008
    • 97
    • Scottsdale, AZ
    The prop came with the boat, I bought used, and the prop had been machined by someone to add performance. It was a good job because there was no vibration at all. This morning I put in and there was some debris in the water and clunk. For sure one of the blades is damaged and I think a second is too. Should I get it repaired or just go buy a new one? Thanks
  • jward
    • Feb 2008
    • 620
    • Sweet Home Alabama
    • 03 SANTE 04 SANTE
    Both!
    • Fwat220
      • Sep 2008
      • 97
      • Scottsdale, AZ
      Okay, so what prop should I get?
      • jimmyj
        • Jan 2010
        • 87
        call delta. tell the what you do and the weight you run and they will recommend something.
        • uwhusky
          • Aug 2006
          • 320
          • Salt Lake City
          • 2015 SANTE 210 w/PCM 450hp engine
          Get the Acme 1235.
          • Fwat220
            • Sep 2008
            • 97
            • Scottsdale, AZ
            The Acme 1235 is what I was thinking. I have an ACME 645 on there right now that has been slightly modified.
            • uwhusky
              • Aug 2006
              • 320
              • Salt Lake City
              FWAT220 - Where do you boat around Scottsdale? Do you head up to Lake Powell often?
              • Fwat220
                • Sep 2008
                • 97
                • Scottsdale, AZ
                I store my boat at Bartlett Lake. It is about 45 minutes from Scottsdale. I have not been to powell yet. I am dying to get up there.
                • uwhusky
                  • Aug 2006
                  • 320
                  • Salt Lake City
                  I have the 645 also but have been told to get the 1235 not only because it's a bad *** prop but also for the high altitudes I tend to recreate at. Powell isn't terribly high but that's where I do 80% of my boating and I don't think it would hurt to pu the 1235 on for that lake.
                  • Fwat220
                    • Sep 2008
                    • 97
                    • Scottsdale, AZ
                    I was told to go with the 1235 not necessarily because of the elevation, but because of the extra weight we put in the boat. The 645 works great now. No lag time. Smooth pull. I like it. My correct craft guy here told me to go with a 1235 if we were to get a new prop. I have been doing some research and have heard some complaints about the loudness of the 1235 prop. I also heard the rpms are pretty high at cruising speed (30+ mph) making it even louder. I then heard that the 1235 takes a few seconds to get the boat from stopped to moving. Have you heard any of these things?
                    Houseboat at Powell?
