This is my first time winterizing my 94SN so please bare with me...
I want to drain the block and manafolds and then re-plug them and pull antifreeze in thru the raw water inlet. I assume I want to have the pink stuff start dumping out the exhaust as I fog out my engine. Of course, I plan to change the transmission fluid and oil first but do I have order correct? Am I supposed to keep the antifreeze in the block and manifild or should I re-open the plugs to allow it to drain once I am done? I've heard of people doing it both ways - which is better? I am in Ohio so a hard freeeze is probable.
One other question - my Pito tubes? Do I have to remove my dash to blow air thru the tubes to keep them from bursting?
Thanks,
Dave
Thanks,
Dave
