2002 SANTE Replacing Steering Cable and/or rudder packing
  • JEbmwRX1
    • Jan 2010
    • 26
    • Raleigh, NC
    • 210 SANTE, black on black.
    I just recently purchased a black on black SANTE and the steering when i test drove it was extremely stiff, almost need 2 hands to turn when going about 23mph. I was planning on replacing the steering cable but not too sure where to start. If anyone could give some detailed instructions and about re-packing the rudder housing with grease? I'm planning on replacing the cable with a OEM cable so I dont loose any steering movement.
    I appreciate any advice or pics. Thanks!
  • jaybird
    • Oct 2008
    • 516
    • North Alabama Lake Weiss
    disconnect the cable at the rudder and you can tell which has a problem. If the rudder will then turn free by hand the cable has a problem. If the steering wheel is free and the rudder is stiff you have a rudder problem.
    If the rudder is the problem it is usually the result of a rudder impact damaging the rudder shaft and or rudder sleeve. When I purchase a Nautique I always opertate the steering in reverse. Grap the rudder and be sure you can turn it thus rotating the steering wheel with the rudder.
    2012 Team Ski Nautique ZR409
    2011 Sport Nautique 200
    2008 SANT 230
    2003 Air Nautique 226
    1988 Martinique
    1979 Nautique
    1978 Tique
    1976 Tique (First New Boat)
