2006 210 team heater install
  • pjbsgm83
    • May 2009
    • 2
    i have a 2006 210 team i recently purchased and i want to install a heater. i ordered a heater direct from heaterchraft and they sent me the 300 series heater. when i went to install under the dash the only place with enough room to mount the heater the center ballast tank pump is located. also does it got hot and need space around it. i have no idea where to mount the unit and could use any suggestions. also it has three ports, one fixed and two of the extendable mounts. i could also use some ideas on the best place to mount these. also for running the hoses up to the heater unit should i run the underneath the floor or will under the gunnels work. i can wire right into the factory wires and i know where to mount the hoses. i was thinking of installing a ball valve from the water pump and wondering if i need one on the other end of the system.
    thanks.
  • AuMDLST
    • Apr 2007
    • 870
    • Orlando, FL (Butler Chain)
    The heater unit goes behind the kick panel at the drivers feet. Typically there were holes cut in that panel for the
    tubes.
    2006 SANTE 210 (Pending Sale)
    2005 206 TE (Previous)
    • pjbsgm83
      • May 2009
      • 2
      yea i know that is where it goes maybe if someone has a picture of one installed that woiuld help cause i dont think i have the room there
