Is it possible that a bad bearing would only show up at higher RPM's? with my 98 196 at idle to 2000 RPM all looks good. 2000 and above the belt starts to squeal and burn. took the belt off and the pulley seems to turn freely. This only seems to be a problem at higher RPM's. Wondering if its the alternator or if something is out of alignment. If it is the alternator is there a part number for one from an automotive store?
Brian
Brian
