I'm starting to repair some of this year's wear and tear to get her back to perfection.
1. I snagged the motor cover on the boom clamp and peeled back a bit of the rubber trim/weatherstrip where the top meets the clamshell. Follow me? I didn't tear anything at all and was able to push the piece back into place. It looked to me, though, that that trim/weatherstripping was sealed or glued to the vinyl to keep water from running down between the vinyl and the back of the weather strip. What glue or sealant can I use to fix this?
2. The top layer of foam insulation under the motor cover is peeling back a bit at the edges. I'd like to re-glue these. Should I use the same glue for item 1? or perhaps something like 3M black or 3M yellow? ...or other?
