After tightening your hose clamps and checking the strainer, run it till you have a problem. Assuming you checked your oil for water as Daniel mentioned.
Is your boat carbed or MPI ? I generally go by the rule that carb = 143* and MPI = 160*. I read the 93pCM manual and they do not specify a stat, just state that operating range is 140-170*.
I have a 143 in the Mustang that fluctuates a lot, and a 160 in the SuperAir and that sticks at 160 tight.
