Question on Winterization and Antifreeze
  • Red57Bird
    • Aug 2007
    • 381
    • Raleigh, NC/Lake Gaston
    • 2003 Super Air
    I hate to start talking about winterizing now, but unfortunately it is coming sooner rather than later. I know there are a lot of threads about how to winterize but I wanted to get some feedback from some of you guys on my method for draining the engine and adding antifreeze. This is how I did it last year and it is probably a bit "over-the-top" but being the first time I had ever winterized a boat, I took the better safe than sorry route.
    After changing all of the fluids and fogging the cylinders, I drain as much water as I can from the block using the normal drain points (tranny cooler, block plugs, water pump drain, and manifolds). I remove the two hoses from the strainer and use a shop vac to blow air through both hoses to try and get as much water out as possible. I remove the heater hoses from the block and use the shop vac to blow water out of the heater core. I hook the heater hose back up and manually pour antifreeze down the hoses from the strainer. I also manually pour AF in the manifold as well.
    This year I'm considering doing the exact same process, except for the part about manually adding the AF. I've read where several owners remove the hose from the strainer, attach an extension hose, place the end of this hose in a 5-gallon bucket of AF, and run the boat until it empties. I figured I'd need to pour some antifreeze in first to prime the impeller.
    Am I making this harder than it really needs to be? My guess is "yes" but wanted to get your feedback. I'm cautious when it comes to the engine and winterization. My neighbor, who is a mechanic, has a MC 205 and he tried to winterize it himself last year. He ended up with a cracked block and a $5,500 repair bill.
    2003 SAN (current)
    2003 Chaparral 220 SSi (sold)
  • MyWakeIsBigger
    • Jan 2009
    • 148
    • Cincinnati
    RE: Question on Winterization and Antifreeze
    http://planetnautique.com/index.php?...ic&t=15650
    • WakeSlayer
      • Sep 2005
      • 2069
      • Silver Creek, MN
      • 1968 Mustang
      You have the right plan. Go with that.
      the WakeSlayer
      1968 Correct Craft Mustang
      • SNobsessed
        • Nov 2008
        • 60
        Red57 - I agree with Mike (Wakeslayer) the important step is to drain all water 1st. The AF is icing on that cake, just an added layer of protection.
        • jmo
          • Mar 2006
          • 735
          • MA
          Yep this is the way to do it. I fill the exhaust manifolds/block manually (after draining of course) and pour a bunch into the hose leading to the impeller, and then use the bucket trick, this way it shortens how long the engine is running before the cooling system is fully primed with AF. Don't forget the pull the impeller and rinse it off and drain the AF out of the Raw water strainer.
          2018 Ski Nautique 200 TE, H6
          • DavidF
            • Sep 2004
            • 611
            • Austin, TX
            Pour it in manually, no need to run engine. Remove hose from output side of raw water pump, turn it upright and fill from there. Done. Good for you in adding the AF, it will help prevent excessive rust scale buildup in the block.
            • ClemsonDave
              • Oct 2004
              • 659
              • Glen Allen, VA
              • Ski Nautique 200
              Never understood why you would drain all the water then add the antifreeze. Several friends of mine just disconnect the intake hose, insert a funnel, run the engine, pour antifreeze (environ. friendly) until it comes out the exhaust. If the antifreeze makes its way all the way through the system, what's the point in draining the water out 1st? You don't need 100% antifreeze in the block for it to prevent freezing.
              Mine only stays winterized for a few days at a time, so I added quick disconnects to the heater hoses. Remove all the plugs and use low air pressure from a compressor to force all the water out of the block.
              Promo Team member
              1999 196
              2010 200 Team 2010 200 Team
              2011 200 Team 2011 200 Team
              2012 200 Team - 2012 200 Team
              2013 200 Team - 2013 200 Team
              2014 200 Team - 2014 200 Team
              2015 200 Team - on the way
              • WakeSlayer
                • Sep 2005
                • 2069
                • Silver Creek, MN
                • 1968 Mustang
                Dave, that is the difference between your winter and ours.
                It will always hit -30* during the winter at some point here. While the mixture statement is true of auto antifreeze, lots of people use marine/rv antifreeze and you do not want that diluted at all. I think it is just easy insurance. I did not drain my block first for many years, but on those stupid cold nights, I would lose sleep.
                David is correct, also, about the anti-corrosion factor using AF.
                the WakeSlayer
                • Red57Bird
                  • Aug 2007
                  • 381
                  • 2003 Super Air
                  Re: RE: Question on Winterization and Antifreeze
                  Good point about the AF in the strainer I failed to mention. I was told that, over time, the AF can craze and crack the strainer bowl. Since I replace the impeller each year, I leave it in over the winter and replace it as part of the summerization process. What I may do this year (if I do the AF manually) is pull the impeller prior to doing the AF, replace with a new one in the Spring, and keep the previous impeller as a spare.
                  Lots of ways to do this stuff, but it is always good to hear what other owners are doing. Thanks everyone for the opinions and feedback.
                  2003 SAN (current)
                  • TRBenj
                    • 1683
                    • NWCT
                    When you dont drain the water first, how do you know what concentration of A/F is in the block? 50%? 100%? 0%? Just because it makes its way out the exhaust doesnt mean that any made it into the block- and if it did, theres no way to verify how much. You could have little to no freeze protection. Maybe you'll be ok if it only sits for a few days at 25-30deg F... but I sure wouldnt trust it much past that.
                    I know people who ski until the lake freezes over. They drain the block and manifolds after each use as a precaution. They only backfill with A/F once theyre done for the year. Thats the most logical (and safest) way to do it, IMHO.
                    1990 Ski Nautique
                    NWCT
                    • WakeSlayer
                      • Sep 2005
                      • 2069
                      • Silver Creek, MN
                      • 1968 Mustang
                      RE: Re: RE: Question on Winterization and Antifreeze
                      Agree 100% with Tim above. Better safe than sorry.
                      the WakeSlayer
                      • Roddyj
                        • Jul 2007
                        • 66
                        dang, winterizimg in nc already? u can easily ski thru mid november here man. well i guess the boat may be at lkg
                        • Red57Bird
                          • Aug 2007
                          • 381
                          • 2003 Super Air
                          Re: RE: Re: RE: Question on Winterization and Antifreeze
                          You are correct - boat is at LKG. We will ride/surf up until the first weekend in November, then I'll winterize the boat then. I wanted to go ahead and get this kind of info up front so I'm not scrambling at the last minute.
                          2003 SAN (current)
                          • jmo
                            • Mar 2006
                            • 735
                            • MA
                            I run the engine to cycle AF after manually filling the block to make sure every nook and cranny are covered, from the transmission cooler, to the heater, etc. This also will flush out any little bit of water that is left after draining. Is it overkill, maybe, but this way I have peace of mind on nights where its drops to single digits outside.
                            • ponycar
                              • Jul 2009
                              • 52
                              • Dallas, TX
                              • 2005 196
                              Does anyone have a picture of the location of the transmission cooler plug? Thanks
                              05' 196
