I am helping a buddy try and figure out why his 01 SAN with a gt-40 has no power on the bottom end. It has a slight miss at low RPM also.
We have replaced plugs, cap, rotor, and wires on the ignition side. We replaced the valve on the pickup at the tank. Replaced the low pressure fule pump because we thought it was a fuel delivery issue. I checked the PSI while running on the rail and it was around 36 PSI. Compression also checks out on all cylinders. I am at a total loss on why its gutless. It will only pull around 4000RPM at WOT also. I think that is just a sign of the weakness of the motor though. We have checked ground wires and power wires also.
Any ideas at all? After checking the usual suspects we are back at square one.
