Where is the speedometer pickup located on a 2007 220 and is it a paddle wheel or tube pickup? My boat has been stuck in the water for a month due to trailer problems and the speedometer has started having problems. The last couple of weeks it hasn't worked when we've started out and after running for a few minutes it has kicked in. Last night it didn't work at all. I'm thinking the pickup may be clogged since it has been sitting in the water, but I'm not sure where to look.
I can't get the boat out of the water for another couple of weeks, so I'm trying to figure out some in water fix. I discovered last night it's a little difficult to wakeboard without a speedometer, especially since I haven't had the boat long enough to track the RPM at different speeds.
