I have a 2007 crossover sv211- none of the breakers are popped and for some reason I can't get those lights to work. Ideas?
Bow lights won't come on
Check out the bulb contacts, sometimes the bulb loses contact with the little spring in the holder due to a bit of corrosion or simply the contact spring may have lost a bit of tension. You might want to apply a little grease to the contact surfaces to prevent future corrosion. If you are going to fiddle around and adjust the contact spring tension a tad you should make sure you have the power supply to the lights off to prevent sparking and some resulatant damage.
