Can someone help out with the PP Settings on a 2006 SANTE? A freind of mine has one and is doesn't seem to hold speed good at all. It doesn't overshoot is just has a problem holding speed. There is 280 lbs of lead from the drivers seat to the front with factory ballasts. I have tried different settigs but I am not seeing a big change. One thing that I noticed is that if the speed is set to 21 the PP will seem to always be less than that. When it does finally make it to the set speed it slows back down.
Tags: None
RE: Perfect Pass Settings for 2006 SANTE
I have a 2003 SAN (330 EX engine) and with KDW set around 135 and NN set around 85 that seems to work pretty well for me. I usually ride with stock ballast plus 600 lb sac in the walkway/bow and a few people in the boat. It generally holds speed within .3 mph of the set point.
