On the first outing after I bought the boat I was able to enjoy it for about 2 minutes before it died and wouldn't restart.
It appears that the boat is starving for fuel as it fires up immediately if you pour a little gas in the carb...I can also see that when you pump the throttle that there isn't any gas coming out.
I checked the anti-siphon valve, and it appears to be functioning correctly - so I think I can rule that out.
So I'm guessing that it is either a blocked fuel line, or the fuel pump is shot. Is there any way to diagnose if the fuel pump is working correctly or do I just purchase another one and see if that resolves the problem?
Thank in advance,
Justin
Thank in advance,
Justin
