New Starter Solenoid - Boat will not start
  • moxiemeister
    • Jul 2009
    • 2
    I've been having intermittent starting problems with my 1998 PCM GT40. When turning the ignition to crank position, there is frequently only a click. After repeated attempts, the engine would crank over and start. I replaced the starter solenoid, which didn't fix the problem and in addition the engine will no longer start, although it cranks over as it did before. Is there a circuit breaker or fuse that I may have tripped in the replacement process?
    The negative battery terminal was disconnected throughout the replacement.
  • mhaaland
    • Jul 2007
    • 217
    • Des Moines, IA
    • 98' Air Nautique
    RE: New Starter Solenoid - Boat will not start
    i had a problem with my 98' not starting & it turned out to be the fuse by the battery. really it was more the fuse harness deal than the fuse. i replaced the whole thing with an 50amp breaker & she's running good.
    1998 Correct Craft Air Nautique DD
    FCT 2 by NDT
    Teak Platform Restoration
    Re-Carpet Trailer
    Oxidation Removal
    Install Automatic Ballast System
    Re-Decal Boat
    Interior Restoration
    • liquid-diet
      • Nov 2008
      • 113
      • Pittsburgh, PA
      • 2001 Super Air Nautique
      try the fuel relays too
      Ryan
      2001 Super Air Nautique 210
      • dalesieg
        • Jun 2010
        • 12
        • 1994 Ski Nautique closed bow
        Did you ever find the problem?
        moxiemeister,
        Did you ever find the problem? I believe I am having the same problem with my '94 Ski Nautique.
        Thanks,
        Dale
        • dalesieg
          • Jun 2010
          • 12
          where can I find the fuse?
          mhaaland,
          Where can I find the fuse and fuse harness on the boat? Is it behind the dash someplace? Also, where should I pick them up if I need to replace them? Also, what does &amp mean?
          Thanks for your help.
          Dale
          • h2ohangtime
            • Aug 2009
            • 92
            • Frisco, TX
            • 2002 Super Air Nautique
            Dale,
            If your GT40 is fuel-injected and has the ECM, it can be found on the back of the motor. There are three red buttons (60, 20, and 15, I believe) and these are the circuit breakers. You can push them and see if you get anything...if they click, that means the circuit was overloaded and broke. That may be what's causing your problem...I was having the same issue on my GT40 a couple weeks ago. Good luck...
            • dalesieg
              • Jun 2010
              • 12
              Thanks. Mine is not fuel injected. Does that mean it is not possible to be the same issue as yours?
              • dalesieg
                • Jun 2010
                • 12
                fixed
                Replaced the starter relay and it fixed the problem. Thanks for the posts.
