I have an 03 SAN with the Excalibur 330 motor. I recently did some maint./repairs that included new bilge blower, new spark plug wires, new belts, etc. The last couple of times I have tried to start the motor, it will turn over and almost starts, then the starter quits. I release the "Start" button and then try again, and the motor turns over and eventually starts. Once I've run it for a bit and it comes up to operating temperature I can usually start it again without a problem. The battery is charged and in good condition, alternator shows 13.5 volts, and everything seems to be in good order.
Does this sound like it may be a starter solenoid going bad, or possibly an issue with the keypad panel? Any ideas or advice would be greatly appreciated. Thanks.
