water temp sensor
  • contour
    • Oct 2004
    • 20
    water temp sensor
    I cannot find the raw water temp sensor on our new 2009 SN. our old 2005 it was in-line in the rubber hose just below the strainer. Our water temp is reading about 10 deg warmer than what the real temp is, so it looks like it's getting some influence by the air/engine.
    • 2909
    • Current 2017 GS22
    RE: water temp sensor
    I believe it's part of the paddle wheel but I could be wrong?
    • nms1991
      • 477
      It is in the paddle wheel, it is not out of ordinary to have the sensor read wrong in the paddle wheel.
      • contour
        • Oct 2004
        • 20
        this sucks, is there any way of making this sensor read accuately, or putting in an older in-line sensor
        • skijones
          • Mar 2005
          • 235
          • COLUMBUS OH
          • 1985 2001 1999 Snob
          If you have perfect pass, the water temp can be adjusted. Go to system, highlight temp and then hit the up and down buttons at the same time.
