already posted on WW but I think the PN community is able to help a brother out!
Last year I would unscrew the water strainer bowl and clean it before every use..now it seems to be stuck, for good. What should I do to set it free? should I remove the hoses , take the filter out of the boat and soak it in hot water?
second issue
I think my heater is busted...sometimes it's hot as ****, sometimes it shoots cold air..I'm getting a good amount of water in the bilge, which happens ever since I'm getting cold air. what should I look for? engine is a EX330 , 02 210TE.
is it possible that my PP (wakeboard pro) is broken because of water in the bilge? it used to work fine (had it fixed over winter) and now the buttons do not work ??? if I press the menu or ON/0ff button nothing happens...
thanks in advance!!
pete
http://www.wakeworld.com/MB/Discus/m...tml?1244595316
thanks guys :S
second issue
thanks in advance!!
pete
thanks guys :S
