Ignition breaker 88 SN 2001
  • midwesttex
    • Jul 2004
    • 36
    • Virginia Beach
    I have had trouble with my ignition breaker popping out on me for two seasons now. Sometimes I go a whole month with it working fine. Most of the time I can hit the breaker before the boat shuts down and everything will start back up. Is this a common problem with older Nautiques? Do I have a short somewhere, if so how do I find it? I am tempted to just put a bigger breaker in. If I do that am I asking for trouble?
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    The breaker may be getting old and weak due to it poping often. I would replace it with the same Aperage breaker. If you have an ampmeter you might want to disconnect the back of breaker and put the meter in line. See if you are drawing to many amps. However I would doubt this is the case
    Nautiqueless in San Diego
    • franky
      • Nov 2013
      • 5
      • Quebec
      • SAN 2000
      hi, We had the same problem on a 2000 SAN. We are still locking for it. Do you fix it ? If yes, what was the problem.
