Alright, First it is a 08 210 with the zr6 so it has the closed cooling system. I was installing underwater led's and notice there is a house not hooked up to anything. It was the outlet from the raw water pump. Its a good thing I stubled apon this as that would probably fill the boat up rather fast. Now there is a tee underneath the motor where this hose is supposed to go to. But it is about 6 inchs to short, I have tried moving it as close as possible but it won't go. I think it is 1 1/4 hose, but I cannot find hose anywhere here. Has anyone ever had a problem like this?
The ZR6 in my previous boat had a quick drain kit, red hose, attached to various pickup points on the manifolds etc.. These red hoses were "T" together and capped at the center thru hull drain of the boat (center on a 196). Similar system to the quick drain for the engine oil. Is this what you are referring to?2018 200 Team H6
2009 196 Team ZR 409
2005 196 Limited ZR 375
2003 196 Limited Excalibur
1999 196 Masters Edition
1987 ProStar 190
