I'm trying to finish my heater and I just need to hook up my hoses. I've found the location of the supply. What is the best place to put the return? Thanks
RE: Heater install 08 210?
the factory hooked it up on the intake between the thermostat housing and the valve cover on the port side of the engine, counter sunk allen head plug, then the other side is hooked up to a plug on the circulating pump that is on the port side of the p;ump and it has a square head. that is on the 5.7 excalibur, now for a 6.0 there is a plug on the port side engine on the thermostat housing and the other is on the back of the motor near the over flow container, there is a fitting with a allen head plug.
