1996 PCM carbed 351, which spark plugs?
    • 2909
    • Current 2017 GS22
    My turn with the spark plug Q...
    Helping my buddy tune up his MB sports. It has a carburated PCM 351, which plugs should I use? I prefer Motorcraft plugs.
    I think they are either BRF3M or ASF32M, for some reason I am thinking the ASF plugs are the right ones but I am not sure. The BRF's are 18mm, the ASF's are 14mm. I don't have access to the boat, need to bring the plugs to the lake with me.
    Thanks,
    Mikeski
  • east tx skier
    • 1561
    • Tyler, TX
    I don't know Motorcraft #s, but for the 351 HO, I used the AL764. For the 351, I think it's the AL24. You might use that to cross reference.
    • Nautiquehunter
      • Jun 2008
      • 2099
      RE: 1996 PCM carbed 351, which spark plugs?
      The BRF3M plugs are 18mm [large plugs] the ASF32M are 14mm [peanut small ] plugs.
      If you use a 13/16 socket use the BRF3M.
      If you use a 5/8 socket use the ASF32M.
      • TRBenj
        • 1683
        • NWCT
        Doug is right.
        E7 (base) heads get the Autolite 24's. GT40 (HO) heads get the Autolite 764's. Id stick with Autolite plugs for the Fords.
        1990 Ski Nautique
        NWCT
          • 2909
          • Current 2017 GS22
          Peanuts...
          ASF32M
