what batteries to get and where
  • gride300
    • Apr 2008
    • 1356
    • mobile, al
    i'm replacing both of the batteries on a buddy's 210 today for him. it's a 2005. any tips on what to get? if it was mine i'd get optima blue top dual purpose but it's not so i'm looking for a decent battery that fits.
  • kevfran99
    • Sep 2008
    • 335
    • ATL
    • 08 210 SAN Team
    RE: what batteries to get and where
    anything that doesn't have interstate written on it!!! Those things are crap!
    '08 SAN 210 Team Black w/Patriot red top stripe-Tow Biminis over the tower-4 under water transom lights-hot/cold shower-crest carpet-full throttle steering wheel-extra 6 channel JL amp-Pro 80's-WS420-fiberglass sub enclosure-led'd vents-Chromax Letters-and Tinted windshield for now......
    Tow Vehicle--05 GMC 2500 Crew Cab Short Bed 6.6L Duramax/Allison with a few mods
    -GO DAWGS!-
    • gride300
      • Apr 2008
      • 1356
      • mobile, al
      i have installed batteries but never in the boat. just any decent marine battery will fit in the box right:
      • WakeSlayer
        • Sep 2005
        • 2069
        • Silver Creek, MN
        • 1968 Mustang
        I never use deep cycle batteries in boats. They are meant for trolling motors and to be run down and recharged. People do use them for stereos on separate circuits. You need a regular cranking car battery if it is for general purpose.
        the WakeSlayer
        1968 Correct Craft Mustang
        • Chris4x4Gill2
          • Jul 2008
          • 406
          • Smith Lake, AL
          • '89 Ski Nautique 2001
          I agree, you need a standard cranking battery. Pull the current one and then get a new one the same size/configuration with equal or greater cranking amps. What brand you get mainly depends on what kind of warrenty you want. I've never had a problem with the "premium" 5yr warrenty batteries from walmart or advance auto.
          If you hae a stereo that uses a seperate battery I'd look int oa deep cycle for it if you want, but a standard battery will work as well.
          • gride300
            • Apr 2008
            • 1356
            • mobile, al
            oh ya i know that. he doesnt have a crazy system so there's no need.
            • WakeSlayer
              • Sep 2005
              • 2069
              • Silver Creek, MN
              • 1968 Mustang
              fyi marine = deep cycle
              the WakeSlayer
              • gride300
                • Apr 2008
                • 1356
                • mobile, al
                it's got a 2 battery set up w/ a perko switch. should i get 1 cranking and 1 deep cycle? my buddy does run the stereo w/o the boat running for long periods of time or will two cranking be fine?
                • 8122pbrainard
                  • Jul 2007
                  • 255
                  Wrong! Marine batteries have the additional stud terminals and usually have handles. The basic lead acid is available as a "cranking", "starting" or some manufacturers do make a combination.
                  • gride300
                    • Apr 2008
                    • 1356
                    • mobile, al
                    so if you wanted to replace the oem batteries on your 2 battery 2005 210...
                    • Chris4x4Gill2
                      • Jul 2008
                      • 406
                      • Smith Lake, AL
                      i would use one cranking and one deep cycle, but thats me i'm sure others have different opinions.
                      but cant you pull the batteries and then just get replacements with the same ratings? you should be able to tell whats in it now
                      • jaybird
                        • Oct 2008
                        • 516
                        • North Alabama Lake Weiss
                        On any 2 battery setup you should use the exact battery of the same age, never use an old and new battery in the same system, and wakeslayer is correct, marine is deep cycle. In a 2 battery setup you should use 2 deep cycle batterys. Optima are your best bet for long term use but they are costly, forget Walmart everlast marine, they are a joke. If you keep you batterys connected to a trickle charger some call a battery maintainer, they will last longer. What kills a battery is allowing it to remain drained for long peroids of time, keep it charged in the off season or it could failed in a single year or two.
                        2012 Team Ski Nautique ZR409
                        2011 Sport Nautique 200
                        2008 SANT 230
                        2003 Air Nautique 226
                        1988 Martinique
                        1979 Nautique
                        1978 Tique
                        1976 Tique (First New Boat)
                        • jaybird
                          • Oct 2008
                          • 516
                          grid300, with most 2 battery systems, the pair is connected by a charging relay when a charge is avaliable but when a load is present like a audio amp, only 1 battery is used so the starter battery is always avaliable even if you kill the other. If you have 2 batterys connected in series without a charging relay and 1 battery goes bad the other will quickly follow if they remain connected to each other.
                          2008 SANT 230
                          1988 Martinique
                          1979 Nautique
                          1978 Tique
                          • Chris4x4Gill2
                            • Jul 2008
                            • 406
                            • Smith Lake, AL
                            I disagree on the optimas. Pricey battery for no benefit excpt the gel cell wich allows you to mount them in any position. I've used the store brand batteries in just abot everything i own from 4x4's and hot rods to bass boats and my daily driver. I've never had one go bad on me sooner than the "warrentied" time.
                            • WakeSlayer
                              • Sep 2005
                              • 2069
                              • Silver Creek, MN
                              • 1968 Mustang
                              I am going to go with Jaybird on this one. I am no 12V electrical expert, but that makes the most sense.
                              Pete, in general, marine/deep cycle batteries are designed for guys that use trolling motors and livewells, and are intended to be run mostly down and charged up, not used lightly, and kept on a perpetual charge. Isn't that what Rangers and the like have shore power charging plugs on them for? I am not sure I get what side terminals and handles have to do with the performance of one. Other than convenience, and dinging people extra money for them.
                              I have seen those "dual purpose" batteries and that would be my dead last choice for a battery.
                              the WakeSlayer
