water disaster
  • Bobby
    • Jul 2004
    • 87
    • Norman, OK
    water disaster
    long story short - my boat (1996 Sport w/ GT-40) had the plug in it while it was sitting outside at my parents' house (usual place of storage). We have had a lot of rain lately and I hadn't had time to check on it in a while. I get to it yesterday and it has about half an inch of water above the floor line. I drained it out, cleaned up the mess, checked the fluids for water except for the gas - which will be checked here later today.
    Now when I turn the key it will make a click sound. It will do this 3 or 4 times before actually cranking over and when it does crank over, it will fire then immediately die. What needs to be done?
    1996 Sport Nautique w/ EFI GT-40
  • darrel409
    • Jul 2004
    • 566
    • San Dimas, So. Cal
    RE: water disaster
    You can start with a generous shot of WD-40 to starter and then check your kill switch.
    • SquamInboards
      • Sep 2005
      • 397
      • Squam Lake, NH
      • '82 2001 '84 2001 '86 2001 '98 NSS '87 American Skier
      RE: water disaster
      Before you do anything check you dipstick and make sure your oil is clean, no h20.
      How 'bout a little reverse action...
      • Bobby
        • Jul 2004
        • 87
        • Norman, OK
        Re: RE: water disaster
        I did that, as well as checked the trans fluid. No water in either.
          • 2908
          RE: Re: RE: water disaster
          probably needs a new starter and battery (maybe an alternator too it it was under water). Nothing serious, these components just don't like being under water for extended periods of time.
          • Miljack
            • Dec 2004
            • 1634
            • Charlotte, NC
            • '08 230 TE ZR6
            Drain the fuel bowl in the FCC (Fuel control cell), if it's still starting then dying, do it again.
            On the starter, your battery cable contacts need to be cleaned at the starter, and you will probably need to replace the starter if it was underwater.
            good luck
            2008 230 TE-ZR6
            • Andrew
              • Aug 2005
              • 891
              • Tuscaloosa, AL
              don't just go by the dipstick!
              take out the drain plug on the oil pan/hose and look to see what comes out. oil floats so if there is any water in there, u'll know right away.....
              by the way, be thankful that u don't have an 80's style direct drive engine cover.... suction is a BIOTCH when one gets surrounded by water! i know from experience......
              • maxpower220
                • Feb 2008
                • 116
                I would take the starter off and clean it with electrical cleaner. If not, you will have corrosion issues with it over the winter. I had a similar issue, but the starter worked fine. After the winter, the starter was rusted solid.
                • Bobby
                  • Jul 2004
                  • 87
                  • Norman, OK
                  thanks for the help guys. I'll be getting back to work on the boat this evening.
                  • M3Fan
                    • 1034
                    If it's starting, then dying after a few seconds then I'd bet it's the low pressure fuel pump. That baby does not like being under water and it hangs just below the floor line. The starter will most likely have to be replaced eventually if it was submerged.
                    2000 Ski Nautique GT-40
                    2016 SN 200 H5
                    www.Fifteenoff.com
