yes, everybody says its really easy, but they forget to mention it can be a pain in the ***. for me, i've got a 96 supersport. first i have to move the battery to make room for fat sacs which means i'll have to make longer cables. no big deal, but then i run into the other wires on the battery. one set i will guess is for the bilge, but the other wire on the positive terminal screws me up. its got a fuse and needs to be hooked up to the battery for the boat to run. (i can't do the test for your alternator where you take the positive off to see if the motor will run).
so how do i wire this to the other battery?
