Problems w/ Belt Breaking
  • eg5161
    • 5
    • Naples, FL
    I have a 2007 Super Air Nauitque 210 TE and The belt has broke 6 times since I had it. I got it October 07 and I only have 120 hrs on it. I dont understand why this keeps happening it is very frustrating. They say the pulleys are rusting but i am getting them sanded down and repainted since i do run it in salt water. I got a new tensioner pulley please help or Im thinking of selling the boat and get the MC because they make saltwater addition. I take care of this boat very well.
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    RE: Problems w/ Belt Breaking
    Check the alignment of the pullies if one os out by 1/8inch it may be pinching the belt and causing failure. Also check that everything thast is driven is freewheeling If one of the accessories is binding it will wer the belt.
    Nautiqueless in San Diego
    • wakecrashin
      • May 2007
      • 376
      MC saltwater edition boats: As soon the as the ballast gauges hit salt water they dont work.
      Did you take it to the dealer?
      • eg5161
        • 5
        • Naples, FL
        belt
        I am going to bring the boat to see if the pulley is out aligned. I have take to the dealer n keep paying I just don't understand if anyone lives by Naples fl I'll be willing to pay for someone to fix it. I just to wakeboard n this is frustrating on a new boat.
        • core-rider
          • 1372
          • Huntsville, AL
          • 2003 Black SANTE
          RE: belt
          Paying for it? Warrenty should be covering this I would think. There are plenty of boats running on salt water and I haven't heard anything like this.
          I agree to check alignment and if the pullies are spinning freely. Also, might want to check belt tension. If it is too tight you will definately see issues with breakage. There are gauges made to check this. What brand of belts are they using? If it's some cheap brand, try going a different route like Goodyear.
          Jason
          All black 2003 SANTE
          -- Southern Fried --
          • eg5161
            • 5
            • Naples, FL
            thanks for the help
            i just got the tensioner fixed 2 weeks ago and the pulleys i am looking into getting stainless steel ones this should fix the problems and i am getting aligned today. I dont know what else is causing the belt breaking. I know other people out there have to have this problem
            • wakecrashin
              • May 2007
              • 376
              RE: thanks for the help
              you shouldnt be paying for anything.. period
              • core-rider
                • 1372
                • Huntsville, AL
                • 2003 Black SANTE
                Re: RE: thanks for the help
                X 1,000,000,000 +
                Just because the tensioner was replaced doesn't mean it's not still too tight. Like I said, they make tools to test the belt tension. If your dealer hasn't already done this... demand they do!
                Jason
                • eg5161
                  • 5
                  • Naples, FL
                  thanks for helping me out do u know anywhere they make stainless steel pulleys? The one guys is kinda steep maybe somewhere else is a better one or the polyamer the hard plastic pulleys to use?
                  • Fatboy206
                    • 36
                    • Dubai, UAE
                    Belt breaking
                    There are a bunch of things you need to check out:
                    Firstly as has been mentioned already, pulley alignment
                    Check that the pulleys are the not damaged in terms of sharp edges that may be cutting the belt
                    Have you checked that the pulleys are the correct ones fitted, width, depth, belt to pulley contact surface area, maybe someone did a fix at some point in time and you have the wrong thing installed (I noticed it on a car one day)
                    Check that you don't have the belt rubbing up against something else on the motor which might be damaging the belt.
                    Check all the pulleys for possible damaged bearings/bushes which can cause alignment probs.
                    I'd be interested to know when you discover the prob.
                    There should be no need to be changing to SS pulleys.
                    • Agent banks
                      • Sep 2011
                      • 69
                      • Jackson tn
                      • 2001 super air
                      hey i just had a similar problem! broke my belt today 2001 san gt 40 5.8 bought a new belt put it on and it immediately started squealing and then after 15 minutes it broke along with some smoke too? whats going on plz help!
                      • nms1991
                        • 477
                        This thread is from 2008, but i will try to help, did you check to see if your alternator or impellar pump is seized or has bad bearings in them you should check those first before you replace the belt again.
                        • Agent banks
                          • Sep 2011
                          • 69
                          • Jackson tn
                          • 2001 super air
                          yea i did the belt actually didnt break i recovered it from inside the engine compart . it split on the in side and half the teeth ripped off. there where no drag marks burn marks or chips any where? im going to go with a bad belt .. at idle the boat didnt have a squeak at all. ill replace tomorrow and hopefully that would be it ... i did check the alternator pully and it moves fine ! thanks ne info would help
                          • hyparks
                            • Feb 2011
                            • 302
                            • Brownhills, United Kingdom
                            • 2001 Super Air 210
                            Had this happen on my gt40 last year. My pulleys were rusting causing it to rip my belt. Cleaned the pulleys and been ok since
                            Current
                            2001 SAN 210, GT40
                            Previous
                            1994 Mastercraft Pro Star 190
                            • Agent banks
                              • Sep 2011
                              • 69
                              • Jackson tn
                              • 2001 super air
                              cleaned up the pulleys and ran like a champ yesterday. thanks hyparks made my day worth it stuck a nice elephant last evening followed by a "failed" wrapped kgb ha!! that hurt!
