Besides the price, is there any reason NOT to chose a Flush-Pro over just a plain tee in the line?
I've seen all the other threads with simple connectors and such...plus variations for external buckets, valves, etc.
The questions I have are:
1. Has anyone had problems with the flush-pro restricting flow during normal operation?
2. Has anyone had problems with the flush-pro water hose connector leaking in or out during normal operation?
3. Has anyone had any problems with the case cracking or leaking?
4. Any other problems?
Right now I have the 1" tee to install between the hull valve and the strainer. But I'd rather install a flush pro in the 1-1/4" hose between the strainer and the trans cooler. This line has a larger diameter and there is a long, flexible run of hose that would make for a nicer installtion than the short, stiff section upstream of the strainer.
There are some benefits to the flush-pro over the plain tee. I'd like to use it but want to be sure it's not a cheap gimmick.
AirTool
AirTool
