keyless keypad problem
  • richard
    • Feb 2005
    • 406
    • HK
    Recently the numeric keypad (01SAN) start an issue that it don't work when first time turn the battery switch, in this moment,also no funtion on the blower botton,no green light atall,notice the light emits a weak light near can't see in daylight, but after few minute wait,(the weak light disapper,the blower can sw on) it start to work, I'm worry it becomes don't work alltime later,any one experience this ,I appreciate for advise.
  • jasper
    • Feb 2005
    • 195
    RE: keyless keypad problem
    richard, I had problems with a keyless keypad. The best way to describe the symptoms is that the keypad buttons do not work or work inconsistently. Sometimes the keypad would show power (the green light) and sometimes it would not. It is probable more than one button is affected since the cause is moisture in the keypad.
    jasper
    • richard
      • Feb 2005
      • 406
      • HK
      I suspect the keypad internal moisture also and thinking have a surgery for it to see if something wrong inside,and want some experience advise before the surgery since I don't expect a wrong cut, jasper,how do you do for your key pad issue?
      • jasper
        • Feb 2005
        • 195
        I purchased a new keypad and replaced it. It is easy to replace, but the keypad was expensive. Since I did not cut my keypad open, I can not give you advice on doing that. It would have been interesting to cut open to see how the keypad was constructed.
        • richard
          • Feb 2005
          • 406
          • HK
          keypad
          I will open it once it become worsierand post the result,it's not big deal, I will seal it with 3M 502,I had open my 2 digital guage and fix it due to , jasper.where you get the keypad and how much is it?
          • 2000SNOB
            • Mar 2008
            • 15
            • Ukiah, CA
            • 2000 SNOB 89 Malibu Sunsetter (sold) 72 Cobra Jet (sold)
            Richard,
            I had the same problem with my keypad. I would get the faint green light, but could not get anything else to work. At first it happened once in awhile and then got worse and worse until it just died altogether. I ended up replacing the keypad. It cost me about $550 from west coast correct craft. It took me all of five minutes to swap out the old one for the new one. That solved all of my problems. I have heard that it was somewhat common for the keypads in the 00-01 to go out.
            • jasper
              • Feb 2005
              • 195
              I purchased a new keypad from a local dealer. You might check White Lake Marine - they advertise on PlanetNautique. I don't know about shipping it overseas, but they might. The cost from the dealer was about $600 USD. Hopefully you will be successful with a little surgery on your keypad.
              • richard
                • Feb 2005
                • 406
                • HK
                Good morning, Just wakeup and see the answer! 2000SNOB had exactly same issue and solved,I feel the giant knowledge power of this site and would and more like to be Nautique owner for ever because this site and so many helpful Nautioque fans, I can surely 90% to open the kepad even it looks fine outside,and woder the price for a new one! I'll post result of the surgery. Thanks all input.
                • AirTool
                  • Sep 2007
                  • 4049
                  • Katy, Texas
                  Please post pictures of the guts and then the seal job post-op.
                  AirTool
                  • richard
                    • Feb 2005
                    • 406
                    • HK
                    next week I come bak from SABA,I'll do it ,also as a security basis, seeking a way to bypass the keyless instead a key ignition switch, appreciate proficient knowthe way how to do.
                    • richard
                      • Feb 2005
                      • 406
                      • HK
                      kepad disasemble
                      The start keypad still can use for some time , notice the '4' bad contact becomes worse recently, take it out and disasemble for inspection, found that is a PCB have IC on it , ,button side is clean looks not bad contact there,water oxidesing can be seen at the edge of parts side, means its not serviceable since this side are sealed with epoxy. some water goning from the sealed edge into inside of PCB and corrode the circuit,the photo shows a clean botton side. ' need more try to fix the '4' problem.
                      • richard
                        • Feb 2005
                        • 406
                        • HK
                        keypad repair
                        after clean the contact with electric contact cleaner, test to boat today,it works fine,
                        will install back to the boat.
                        • jasper
                          • Feb 2005
                          • 195
                          Richard, thanks for posting the pictures and for the report back that it works. Congratulations on a successful surgery. Hopefully the repair will last and you can avoid the cost of a new one. You might have given future holders of bad keypads hope for a more economical fix.
