So I took my boat camping this weekend, and showed up Friday afternoon and put the boat in the water (keep in mind, first time this season), and it ran like a champ up and down the lake, multiple engine start and stops, nothing wrong at all. Well I go to fire it up Saturday morning and I have nothing past idol. Hit it and it takes off, and the studers pretty bad and wants to go back to idol. It did this for the rest of the weekend.
Notes:
It did this to me before, and it was the air filter that was dirty and needed to be cleaned.
Just put a brand new battery in
I pulled the hose off the fuel pump intake and it was sucking pretty good.
I did pull the fuel filter out and gave it a shot of air from the air compressor, and some dirt (little bit, but noticeable amount came out) I did however try and run some water through it with gravity pressure and I would get nothing, and if i flipped the inlet down, it would trickle out, and if i shook it I could feel the water shaking inside.
PS i will for sure put a new filter in after the water test.
Any ideas?
Notes:
Any ideas?
