Sometimes I have a chirping noise at low rpm's. Any ideas what it could be? It seems to do it more after the boat has been run for 15-20 min or so. It sounds like it is coming from the drive shaft or tranny.
RE: chirping noise in a 93 sncb
sure it is not the fan belt?
HUMAN BUILT = HUMAN FIXED
switchbait.com
Could be the main control valve of the tranny. Believe it or not, that could be trans fluid under pressure making that noise. Typically this was only an issue on the very first PCM PP trannys. I don't know if it was an issue on the 93 PP trans. There is a kit to fix it that Skidim.com carries. You might want to ask them if it could apply to your trans.
