Make a short jumper wire with a 1/4 spade connector on each end. Unplug the fuel pump relay. Connect pin 30 and pin 87 pin the relay socket. This should cause the fuel pumps to run.
Do not run the engine this way. Jumping the relay connection like this over rides every safety feature in the engines fuel system. Use this test only to verify that the fuel pumps work.
