I have been having this problem for what sems like FOREVER. This is what happens.
While under Idle my boat (02 Air with PCM 351) dies. The dash temp gauge reads 140. It dies like some one hit the stop button. If you try to re-start it it will turn over and just die. The only thing that will make it re start if lifting the engine cover. Its like a breath of fresh air to the motor allow's it to start up. Dont know why but this works everytime
Some other things its doing. So after it dies and I lift the lid and it either cools down or gets fresh Air you can hear the fuel pump cycle. Only after you hear the fuel pump cycle with it re start. This usually take's between 5 and 30 seconds after you lift the engine cover. The fuel pump cycles and then it fires right up.
I have replaced the Relays at the back of the motor.
I have replaced the starter solonoid.
I have taken apart and cleaned out the Flame arrestor and the Idle circut sencer on the throttle body.
I have replace the Main computer on the back of the motor.
I tryed disconecting the neutral switch on the transmission.
I even installed some computer fans on the back of the Computer thinking that the computer was getting hot and causeing the boat to die. Im at a total loss. Any help would be great.
Thanks in advance I have been chasing this problem forever.
