Cap and Rotor Installation question...
  • rbroome
    • 5
    • Orlando, Florida
    As part of a spring tune-up I was planning to replace the cap and rotor on my 97 Sport with GT-40. Are there any special techniques required or lubricants needed on the parts? I know to be careful changing one plug wire at a time. Thanks for any suggestions...Rob
  • rbroome
    • 5
    • Orlando, Florida
    RE: Cap and Rotor Installation question...
    I heard that Di-Electric Grease was a good idea...just wondering where it should be applied. Thanks, Rob
    • hourglass
      • Mar 2010
      • 248
      • lower bama
      • 2005 SANTE
      bump-same for ex330?
      • gride300
        • Apr 2008
        • 1356
        • mobile, al
        double bump. any tips for someone who's changed plugs but never cap/rotor?
        • AirTool
          • 4049
          • Katy, Texas
          apply the stuff inside the spark plug boot (both ends) and on the cap where each wire connects (and the coil if you have one).
          You want the grease to lube the metal connection and the rubber boot so you can get it off later.
