Transmisson fluid leak - Excaliber 330 engine
  • jsimpson
    • Aug 2006
    • 30
    • No. California
    • 2003 206 signiture
    2003, 206 w/330 Excaliber, 308 hours:
    I'm finding a small pool of transmission fluid under the front of the engine (under the belts) Obviously fluid is traveling due to position that boat is stored in. Where do I start, are there any common issues with oil coolers & lines - do the transmission have one??)
    Transmission fluid changed every 100 hours or at begining of season
    Any advice would be appreciated!
    thanks! :?:
  • M3Fan
    • 1034
    RE: Transmisson fluid leak - Excaliber 330 engine
    No common issues that I'm aware of. Try toweling off the underside of the trans and putting a few paper towels underneath. Then look for trans fluid drops a few days later. I had a leak in the front seal of my trans. Wasn't too bad of a job to replace.
    2000 Ski Nautique GT-40
    2016 SN 200 H5
    www.Fifteenoff.com
    • jsimpson
      • Aug 2006
      • 30
      • No. California
      Thank, I'll try to figure out where oil is coming from, what causes a seal to fail?
      • M3Fan
        • 1034
        High water left in the bilge can cause corrosion and pitting around where the seal rides on the input shaft which can mar the seal. Have you ever had standing water in the bilge for any length of time?
        2016 SN 200 H5
        www.Fifteenoff.com
        • 78LS2
          • Oct 2006
          • 183
          make sure the connections from the gear to the cooler are tight. then, try the towel under the gear trick as mentioned earlier.
          \'03 196 LTD
          • JUST-IN-TIME
            • 293
            • ON YOUR BOAT
            the hose that comes off the top are know for blowing up
            might be over filled also
            HUMAN BUILT = HUMAN FIXED
            switchbait.com
            • jsimpson
              • Aug 2006
              • 30
              • No. California
              PCM Transmision fluid leak
              Fund the leak, cooler hose worked loose from the transmission!
