Investigating a problem on my 90 SN and found that the top of the rotor looked toasted and I think the end was burned off. Prestolite screw down - the rotor should have a 'T' on the end, right?
Plus, the contacts inside the cap looked like they had some metal smeared on them.
The boat has a breakerless ignition module:
http://picasaweb.google.com/tapenick...85794605325602
The power wire to the module bypasses the ballast resistor... so does the + to the coil. Wondering if the coil is getting too much power causing it to fry the cap / rotor? Thinking the power to the coil should still go through the ballast resistor.
One more - if so, think there may have been any damage to the coil?
Okay, one more easy one - the dizzy cap gasket is shot.... could I put a little silicon under it if the new cap doesn't have a gasket?
Tom
Tom
