We were skiing the course on Monday and the boat just died and won't restart.
After some help from the dealer diagnosing the problem, I replaced the relay, no change. Next I replaced the filter and high pressure fuel pump and it still won't start.
I have fuel at the return line, but no pressure at the Schrader valve.
When I unplug the 2-wire connector going into the FCC, I get voltage between the wires, initially, then it goes to zero and comes back while cranking.
Any other ideas?
2001 Ski Nautique c/b with keyless ignition, GT 40 Pro Boss
Any other ideas?
