Issue #1: This past weekend in between downpours of rain, we were able to get out on the water for a few passes. We let the boat warm up for about 5 minutes. Temp was up to 160 and holding nicely. Then, when I was skiing, the engine kept cutting out. A sort of "clank" sound could be heard in the boat and the engine would sort of die for a second and then come right back. It did this later in the day for a little while too, but after some easy cruising (around 2000-2500 rpm) it worked its way out and didn't happen the rest of the day. Any ideas? Did I maybe have something stuck in the fuel filter or line?
Issue #2: When turning sharply at lower speeds (but still on plane) a strange noise is heard from the rudder area. It starts like a high pitched squeek, then through the turn becomes lower pitch, then as I'm coming out of the turn it goes back to higher pitch before going away as the boat comes straight.
Do I have some crazy boat demons or what? Any thoughts or suggestions on things I could check for these two issues would be greatly appreciated.
