I am looking for another arm to buy or a work around. Does anyone know of an alternative that might be ok to use?
RE: 99 SS Nautique Hydraulic Hatch Arm Needed
I took my arm out for space reasons, it was taking up valuable fat sac space. When I want to hold up the hatch I just use a telescoping pole that was from a mop or dust sweeper and use a hitch pin to hold it in place where the arm use to be. It works great.
most boat mechanics just have those things around there shop. I was in one a while back and saw some. If you can't find one I can probably get one for next to nothing. Check with a few boat repair shops and I bet you find one. good luck
Mine is laying in the basement. I took a piece of PVC and cut to about 3 ft. , rounded the top edges, drilled hole for pin, put a rubber foot on other end and works great. Motor is way to slow and takes up space.If you don\'t do it today, you will be one day older when you do!!
My linear actuator just went bad as well. Anyone know where I can get a replacement? Can someone measure theirs and let me know how long the body is and how much throw there is on it. Mu boat is at the cabin and I forgot to measure it.....Player\'s Edition SSN. Pimpin\' the rest....
I can dig for the measurements here at my office, I had Zman call me with his when mine was not working. Turned out it was just the fuse. Have you tried that ? CC used to want $1200, I found a company that is at about $120, and my solution was $0.12.
http://www.firgelliauto.com/product_...;products_id=8the WakeSlayer
1968 Correct Craft Mustang
will have measurements in an hour for you.the WakeSlayer
Yep, I pulled the arm and hot wired it straight to the battery and got nothing. It has been intermittent for about a year now and it finally gave out altogether. If you can dig up those specs, I'd appreciate it.Player\'s Edition SSN. Pimpin\' the rest....
Rock Troy
sorry, dude I never got a call back with the measurement, and my boat is buttoned up for 2 weeks while I go out of town in the morning. I will PM my mobile # to you and call me at like noon central tomorrow, and I will get them for you. Promise.
Mikethe WakeSlayer
