G23 Surf Settings
  • JGallagher80601
    • Jul 2025
    • 8
    • Private Lake in Colorado
    • Brighton Colorado
    • 2013 Super Air Natique G23
    G23 Surf Settings
    Start of another Summer and still trying to figure out my 2013 G23 wake surf settings.
    Most of the time - we end up with 8 or more adults on the boat and I’m struggling to find the right set up to surf. We are all beginners for the most part.
    when you’re body heavy - is there a general set with filling ballasts? I would assume more in the belly then Port or Starboard ballasts?
    Any suggestions would be greatly appreciated.
    P.S. Does it make sense to start by saving settings based on the number of bodies on board rather than name? Until we get better and ride with 3-4 people on board I figure I need help with basic set up more than individual custom set up.
  • Scooter G
    • Jan 2022
    • 1505
    • On a Lake in Idaho
    • 2022 G23 ZZ8
    8 adults should punch out a decent wave I would think.
    Are you placing a few more bodies to the surf side? Does that help?
    What speeds are you running?
    Experiment with every combination possible. Bodies up front, heavy on one side, ballasts filled to capacity, speed, slight turn left, slight turn right, and fuel levels. Water conditions and depth can also change wave results (just when you think you have it all figured out).
    Are you wanting a longer or taller wave, or both? What don't you like about your current results?
    Are you running any additional weight (lead)? You probably don't need to with 8+ people, but when you start dropping the head count you may want to consider that. There are some good threads on that discussion.
    I want to say it probably took us a whole season on our current G to really get the wave dialed in under different conditions. Experiment...
    Good luck.
    • JGallagher80601
      • Jul 2025
      • 8
      • Brighton Colorado
      Thanks Scooter for your response.
      what’s your go to setting for your G? Looking for a set up to build off of, mainly for beginners who haven’t tried surfing yet.
      • Scooter G
        • Jan 2022
        • 1505
        • 2022 G23 ZZ8
        Your settings will be completely different, a different hull design, and we have supplemental ballasts. I think we are running around 3 to 400 lbs of lead. Mostly up front and port side. Surfing between 11.4 and 11.6 MPH, a little slower for beginners.
        Our '16 G23, we were running 8 to 1000 lbs of lead. We would run the bags to start at 80% x 3, and adjust on the fly to compensate for people placement and conditions.
        Beginners need a smaller less intimidating wave to start out. Everyone wants to throw the rope for some reason, lol. We tell them to stay on the rope until you can gas and brake in the sweet spot for at least 60 seconds.
        I think if you poke around a little in here you will find some really good threads on set up. But it comes down again to just time on the water and experimenting.
        That wave picture in our avatar is behind our '16 G.
        • Lockem25
          • Oct 2021
          • 61
          • Kentucky
          • 14 g23
          We have a '14 G23 so very similar to your '13.
          Ballast 100% full with that many riders but for beginners we are 3 and 3. For a more confident rider 0 and 5. We also ended up adding 400lbs of lead and i think supplemental ballast the rear lockers last year but with that many ppl on the boat we do not fill them all the way up. We also mainly ride at 11.5mph.
          Like Scooter said. Move ppl around on the boat to get what you want out of it. It will definitely throw a great wave and give a lot of push but beginners may not always be ready for that much.
