2007-2013 210 surf setup
  • evanrude
    • Aug 2014
    • 87
    • Dayton, Ohio
    • 2009 210 2015 210 2006 220
    I think the hauls on the 210 are the same from 07-13???, I just bought an 09. I have searched for a thread on ballast setup for surf but have a question.
    What are you doing for ballast on these hauls when using a suck gate for surf? Is it best to pull hard tanks and replace with bags and add a bow bag under front seats? What size bags are you putting in the rear if pulling hard tanks? Is there a difinative thread out there addressing this? If so can someone point me to it?
    Thanks in advance!
  • swatguy
    • 1669
    • Midwest/ Northern IL
    • 2008 SANTE 210
    I have an 08 210. My boat has NSS. If you’re planning on surfing, Pull the hard tanks. Put 1100’s in the rear. When you do that you’ll need the piggy back sac to put in the center locker and about another 350-400 lbs of lead in the bow .
    search my name and I do a step by step and have couple surf setups .
    • evanrude
      • Aug 2014
      • 87
      • Dayton, Ohio
      Quote removed by Admin for not following the Guidelines for Quoting Previous Posts in a Thread.
      Swat, I had read your post and step by step, very informative. I have seen some discussion back and forth about 1100 vs 750.....trying to decide which is best to go with.
      • scottb7
        • Aug 2011
        • 2198
        • Carson City, Nevada
        i had a 2008 210, and i think the 1100s are best. however, i didn't bother to piggy back. it seemed to be too much trouble relative to how little it filled. i went with a 650 center locker sac that i put under the love seat, cause it was before the suck gates came out.
        these days i would obviously get a suck gate, but i still would not piggy back, i would just put the 650 in the walkway as you can move it forward/back exactly where you want it and skip the lead.
        and it was great to add weight in the bow with the center locker sac on the floor all the way forward, and have the 1100s empty when i had a guy or two that wanted to ski. the weight in the bow, with nothing in the back smoothed out the wake really well.
        • Nautiquehunter
          • Jun 2008
          • 2099
          Piggy back 300s in each rear locker add the arrow shape bag in the front piggybacked to the belly tank. By piggybacking the bags the gauges will still work you just have to push the fill button twice. Add a suck gate set the speed at 10 mph and you are in business
          • scottb7
            • Aug 2011
            • 2198
            Nautiquehunter's post reminded me of something that I forgot. There is a trade off. If you pull the tanks and put in bags your gauges will obviously not work. If it bothers you to not have working gauges this may be a problem for you. We found with the 210 on stock ballast only that we were running full ballast anyway so we did not really use the gauges, as we were filling until over flowing anyway. (And when you piggy back the gauge is gonna read full).
            As a guy that does his own boat maintenance, I found that when the tanks were gone you could jump in on either side of the engine and change the plugs, reach around front of motor, change oil pressure sensor, or whatever else so much easier.
            Also as is noted below you really start measuring how much water you have with "button presses". You know that one button press is stock ballast. And then you kind of decide based on number of riders and surfing or wake-boarding, and how big you want the wake if you want another 1/2 button press or minute or minute and half extra.
            A bit of subject change but the 210 and 230 as surfing machines are IMHO highly underrated. The 210 and 230 waves for surfing are clean, and pretty long...
            • swatguy
              • 1669
              • 2008 SANTE 210
              I echo Scott. I do all my own maintenance . I also tow some long distances and have 2 kids who surf and wakeboard so we have a total of 4 wakeboards and 3 surfboards we need to take with us everywhere. I couldnt carry or store all that in my boat with the tanks still in. We fill by button presses. Its pretty easy to gauge that way. The tanks are so small I dont know anyone who would ride and need to keep them 1/4 , 1/2, 3/4 full. The amount of difference in the wake is almost almost negligible there , usually the tanks are either full or empty. So the button press for us is sufficient and a much better gauge on weight.
              Ive always toyed with the idea of demolishing the center tank and throwing a much bigger sac under there . I feel if that tank was gone you could get way more weight in there hidden.
              • martymizah
                • Jan 2018
                • 112
                • Mi
                • 2009 SANTE 210
                2009 210...i have 550s piggy backed in the rear and a 300 piggy backed in the ski locker. That all full with a mission delta stuck to the side does great. I run at ~11mph
                -martini
                • jtosborn
                  • Sep 2012
                  • 11
                  • Columbus
                  • 2002 Super Air Nautique-Team Edition
                  Are you guys putting the suckgate as far down and back as it will go?
                  • Chad52
                    • May 2004
                    • 295
                    • Huntsville, AL
                    • 2008 Super Air Nautique 210 2003 Super Air Nautique Team 210 2001 Super Air Nautique Team 210 1999 Super Air Nautique 210 1994 Mastercraft Prostar 190 1992 Manta Ray 189 Sport
                    I agree with Swatguys set-up. Pull those hard tanks and never look back. If somebody needs a pair from an 08 210, let me know. I just can't bring myself to throw them away...
                    • TheDengler
                      • Jul 2017
                      • 39
                      • Cleveland, Ohio
                      • Former: 1991 Ski Nautique 2008 Super Air Nautique 210
                      I am curious as well. I usually put my nauticurl as far back and low as possible and get a really nice wave but curious if there is a better position
                      • Hyperlite907
                        • Aug 2023
                        • 4
                        • ON
                        • 2011 Super Air Nautique 210
                        Where can I get a suck gate?
