Where is the "Engine Cooler"
  • 03Air210
    • Aug 2006
    • 95
    • Charlotte NC
    I winterized my closed cooled ZR6 over the weekend and the one engine part I could not figure out was the engine cooler. where is it?
    Todd
  • skijones
    • Mar 2005
    • 235
    • COLUMBUS OH
    • 1985 2001 1999 Snob
    RE: Where is the "Engine Cooler"
    You have a heat exchanger. Look where your raw water lines come in and follow them.
    • Rick
      • Mar 2004
      • 1250
      • San Diego, Ca
      The engine cooler is the heat exchanger where the raw water interacts with the closed system. As skijones says, follow the raw water lines to the tranny cooler then the engine heat exchanger.
      Nautiqueless in San Diego
      • boatech
        • Aug 2006
        • 247
        long round object with cooling sys hoses going into it usually says "NO STEP" on it.
        • 03Air210
          • Aug 2006
          • 95
          • Charlotte NC
          On the list that I got from this site it had the heat exchanger and engine cooler listed as 2 different things. I drained the exchanger but I just wanted to be sure I was not missing anything else. If they are the same then great.
          thanks
          • TRBenj
            • 1683
            • NWCT
            Re: RE: Where is the "Engine Cooler"
            thanks
            Did it also mention the transmission cooler? Make sure you drain that too.
            1990 Ski Nautique
            NWCT
            • 03Air210
              • Aug 2006
              • 95
              • Charlotte NC
              RE: Re: RE: Where is the "Engine Cooler"
              It did not. Where is that plug?
              • CradGen2
                • Aug 2020
                • 1343
                • Horseheads NY
                03,
                I am not sure there is a plug. I normally disconnect the front hose and let it drain. I have to say I have not done a closed system, so not completely sure they are the same. I will try to read the owner manual this evening on the 6.0 L. I think I have one at home.
                • TRBenj
                  • 1683
                  • NWCT
                  Re: RE: Re: RE: Where is the "Engine Cooler"
                  Actually, I have no idea if you need to drain the tranny cooler or not. With a closed cooling system, the coolant may circulate through the tranny cooler instead of water. Im not familiar with the closed system at all- its worth taking a closer look at your manual and engine.
                  1990 Ski Nautique
                  NWCT
                  • skiinxs
                    • 374
                    • St. Louis
                    • 2019 Ski Nautique 6.2 arriving soon
                    RE: Re: RE: Re: RE: Where is the "Engine Cooler"
                    You will need to drain the transmission cooler. Follow the inlet hose from the shutoff valve to a metal tube around 4 inches diameter and around 8 inches long. You can either remove the drain plug or just pull off the hose and angle it down to drain well. On the 6 liter you have the heat exchanger, exhaust and raw water pump to drain. I am not sure about the wakeboard boats, but the ski boats have a central location under the front of the engine with hoses from the heat exchanger and both manifolds. You can pull the plug out of the bottom of the fitting where they all come together or just pull one of the hoses off. This is REALLY handy. I didn't trust it the first few boats, but have found that this drains it really well. Don't forget to unscrew the clear bottom from the sea strainer and dump the water out, that can freeze and break as well. While it is off clean out the screen and make sure you don't lose the rubber gasket. You will also want to change the oil before winter, don't let the dirty oil with all of the corrosive contamination sit in the engine all winter long. This really is an easy engine to winterize. The block has antifreeze as well as the heater. (no more "blowing" your heater hoses!
                    Dave
                    16 other Ski Nautiques
                    3 MasterCrafts
                    18 Ski Supreme's
                    1 SlickCraft Squirt Boat
                    • 03Air210
                      • Aug 2006
                      • 95
                      • Charlotte NC
                      Thanks guys, you have been a big help.
                      Todd
                      • boatech
                        • Aug 2006
                        • 247
                        you did vbox as well right?
                        • 03Air210
                          • Aug 2006
                          • 95
                          • Charlotte NC
                          I did pull the water drain plug on the front right side and nothing came out. Do I need to pull a hose off?
