WOT - Speed / RPM / Prop / Elevation / Octane / Year / Hull
  • FloridaNautique
    • 58
    1. Max RPM at Wide Open Throttle
    2. Max Speed at Wide Open Throttle
    3. Year of Boat
    4. Manf. & Model
    5. Engine
    6. Transmission gear ratio
    7. Prop dimensions (# of blades and pitch)
    8. Octane of fuel
    9. Normal operating Elevation
    10. Anything else you want to add that may make performance different
    It will be interesting to see how boats with the same setup compare
    2007 Ski Nautique 196
  • Miljack
    • Dec 2004
    • 1635
    • Charlotte, NC
    • '08 230 TE ZR6
    OK I'll play
    1. 5200 rpm
    2. 53mph
    3. 1999
    4. Correct Craft Pro Air
    5. PCM Python-8.2l, 430hp
    6. 1.23:1
    7. 13.7" x 17.5" ACME 380 4 blade
    8. 87
    9. 850 feet
    10. top speed listed with only driver, no gear, 3/4 fuel
    Jack
    2008 230 TE-ZR6
      • 2908
      1. Max RPM at Wide Open Throttle = 5200
      2. Max Speed at Wide Open Throttle = 44-46MPH depending on tower load/wind condition
      3. Year of Boat = 2005
      4. Manf. & Model = SV211
      5. Engine = EX330
      6. Transmission gear ratio = 1.45?
      7. Prop dimensions (# of blades and pitch) = ACME 1160 13.5x16 0.135pitch
      8. Octane of fuel = 89
      9. Normal operating Elevation = 500-800ft
      10. Anything else you want to add that may make performance different = Aluminum offshore style high flow exhause manifolds
      • Rick
        • Mar 2004
        • 1250
        • San Diego, Ca
        1. Max RPM 5000
        2 Max Speed 48MPH
        3.Year of boat 2000
        4. Ski Nautique
        5. GT-40 EFI
        6. 1.23
        7. Acme 12.5X15.5x1
        8. 87 Octane
        9 Elevation 6500 Ft.
        10. Add 200 rpm and 2 MPH at sea level
        Nautiqueless in San Diego
        • darrel409
          • Jul 2004
          • 566
          • San Dimas, So. Cal
          1.Max RPM=4850
          2.Max Speed=47.5
          3.Year boat=1995
          4.Model=Ski Nautique
          5.Engine=1993 Carbed ProBoss
          6.Trans=1.23:1 PCM
          7.Prop=ACME 422, 4Blade
          8.Octane=89
          9.Elevation=268ft
          10.Two peeps, 2/3 fuel, 100 degree temp, all normal gear, full case in cooler.
          • BP22
            • Jan 2007
            • 248
            • Covina, CA
            • 2006 Super Air Nautique 210
            1. Max RPM at Wide Open Throttle - 5200
            2. Max Speed at Wide Open Throttle - 42 per PP
            3. Year of Boat - 2006
            4. Manf. & Model - SAN
            5. Engine - Exc 330
            6. Transmission gear ratio - Stock
            7. Prop dimensions (# of blades and pitch) - 4 blade Acme 1465
            8. Octane of fuel - 87
            9. Normal operating Elevation - Sea Level
            10. Anything else you want to add that may make performance different - 3 people, empty ballast, gas tank 3/4 full, pulling a skier
            Brandon
            2006 SAN 210
            • NCH2oSki
              • 1159
              • Maryville, TN
              • 2005 ski nautique 206 SE
              1. Max rpm at wot 5000
              2. Speedo reads 45mph not sure, I havent calibrated it yet, and dont have PP YET.
              3. Year 1999
              4. Model Sport Nautique
              5. Engine GT-40 310hp
              6. PCM 1.23.1
              7. Prop stock oj, 4 blade 13 x 16
              8. Fuel 89
              9. Elevation 813 or 956 depending on lake
              10. Notes: Original plugs, wires, and fuel filter (120 hours). Bimini up 2 people, 1/2 tank of fuel. Noted dry weight is 2700lbs. less tower.
              Prior Boats:
              1999 Ski Nautique GT-40
              www.skiersofknoxville.org
              • M3Fan
                • 1034
                Originally posted by Rick
                1. Max RPM 5000
                2 Max Speed 48MPH
                3.Year of boat 2000
                4. Ski Nautique
                5. GT-40 EFI
                6. 1.23
                7. Acme 12.5X15.5x1
                8. 87 Octane
                Rick, that must be one magic GT40 if it can turn 5200 RPM at 50 MPH at sea level. I've got to throw the flag on that one.
                2000 Ski Nautique GT-40
                2016 SN 200 H5
                www.Fifteenoff.com
                • M3Fan
                  • 1034
                  1. Max RPM 5000
                  2. Max Speed ~45-46mph at this RPM
                  3. Year: 2000
                  4. Ski Nautique
                  6. 1:1.23
                  7. ACME 422
                  8. 87 Octane
                  9. Elevation, near sea level (Chicago)
                  Here is the video: http://www.fifteenoff.com/multimedia/videos/gt40.mov
                  2016 SN 200 H5
                  www.Fifteenoff.com
                  • jdkenyon
                    • Apr 2007
                    • 15
                    • Twin Falls, ID
                    2. 44
                    3. 1994
                    4. SAN
                    5. 351 Carb'd Pro Boss
                    6. 1.23:1
                    7. ACME 1442, 3 blade13.5"x15
                    8. 91
                    9. 4100
                    94 Ski Nautique
                    • TRBenj
                      • 1683
                      • NWCT
                      Though its possible he has a fast hull (they all pop out of the mold slightly different) and a strong motor, I just dont see it being 5mph faster than a typical TSC1/GT40, so I'll have to agree with M3Fan. If youre relying on the PP for the speed, its probably not accurate. My dad's Excal 196 reads 49 on the PP, but is only capable of 45 on the GPS.
                      1990 Ski Nautique
                      NWCT
                      • SpiderMan
                        • Sep 2006
                        • 5
                        • Fennville, MI
                        In fact Chicago is around 580 feet above sea level, though it is near Lake Michigan level.
                        • noti_dad
                          • Jan 2005
                          • 214
                          That's classified. I could tell you, but then I'd have to kill you. LOL!!!
                          2. Max Speed at Wide Open Throttle = 42-43MPH
                          3. Year of Boat = 2006
                          4. Manf. & Model = SV211 Team
                          5. Engine = EX330
                          6. Transmission gear ratio = 1:1
                          7. Prop dimensions (# of blades and pitch) = ACME 1234
                          8. Octane of fuel = Regular (89?)
                          9. Normal operating Elevation = Sea Level
                          • Rick
                            • Mar 2004
                            • 1250
                            • San Diego, Ca
                            I will defer on the speed issue as speedo's are notoriously wrong. The WOT though does give me 5200 rpm. at 384 feet, our lake here in San Diego. I'll take my GPS with me next time I'm out.
