Tube Towing
  • GMLIII
    • May 2013
    • 2821
    bturner I’m not much of a tube puller either but we do on occasions when the kids have friends around the lake. Yeah the Molecule is huge but as you pointed out not much touches the water other then the balls
    • FMSki 'n Surf
      • Apr 2026
      • 41
      • Sproat Lake
      • 2007 SV-211
      I would estimate the max forces as :
      Rec skiing 50-300
      Slalom skiing 300-750lbs (we measured this using a strain guage got over 600lbs)
      Wego Kite tube - will try to get a reading next time we fly
      Tubing 500-2000lbs - if you dunk a tube or have 2 tubes with 4 burly dudes the pull is pretty stout. 2K on a tower is too much imo, just the leverage it has on the boat.
      A couple of kids no problem tho.
      • charlesml3
        • Jan 2008
        • 2487
        • Lake Gaston, NC
        • 2022 G23
        I love all of these comments about the "tower breaking." Please. I watched a video where someone bought a flood totaled SANTE 230 from Copart. There was no trailer so the went over with this huge forklift and picked up THE ENTIRE BOAT from the tower. Yes. They picked up the boat from the tower and put it on a flatbed.
        I'm going to go out on a limb here, but I'm pretty sure if the boat can be picked up by the tower, that tower is plenty beefy enough to tow a tube.
        -Charles
        • FMSki 'n Surf
          • Apr 2026
          • 41
          • Sproat Lake
          • 2007 SV-211
          Picking the boat up on the tower is the ideal loading. Straight in line with the deck. 1800 lbs per side spread evenly. And you'd have to inspect for any cracking at the mounting pts after doing that imo. Better to use lifting straps like most professionals.
          Pulling off the tower is leverage or torque. So 1000lbs at the hook is 4000 ft-lbs on the deck, in torque - uneven loading on the fasteners.
          I worked the #'s for my pylon. A cheap teleflex ski pylon with the tripod stays at the rope hook sees WAY less force than a floor mounted Ski Nautique pylon. I had to design for that leverage.
          • Scooter G
            • Jan 2022
            • 1509
            • On a Lake in Idaho
            • 2022 G23 ZZ8
            3 up, 2 on the tower, one on the stern.
            Remind me to grab that 4th rope next time...
